englsiche step by step Anleitung für meinen Yugi - Das-Bemalforum
    At first I tried to find something in the same size, which is 1/8 and made a wire frame in this size. I used my 1/8 Cloud forcomparing the size. Then I covered the frame with fimo, which is a european putty that hardens in 30 mins at 130蚓 in the oven.
    when that was finished I started sculpting the head. There is no special reason for starting whith the face, but in my opinion when you recognize the charakter you have it easier to finish the rest. For all this stuff I mix green stuff from kneadite with fimo (2/1) the fimo hardens in the green stuff after 2 or 3 days and makes it much more easy during the sculpting process, because the green stuff is more smooth.
    the next step was his chest, which I wanted to make broader. Then I made the millenium puzzle. I made it as an extra piece, and added it here just for size reference. I didn`t like the chain so I searched for another one. Everything until now needs sanding, beacuse there are some fingerprints in the putty.
    after that I mixed greenstuff with miliput, which becomes really hard. I wanted to make his trousers out of this material, because you can sand it faster then the fimo gs mix and make nice folds.
    No after the basic stuff was finished I added his belts and the first version of his shoes. I had to wait to finish his shoes off until I could remove him from the cd. Now I added the right chain and the puzzle at his chest.
    after that I added his jacket. the main part is gs/fimo, the arms are gs/miliput again. now just a few cards his hands and a few more belts and details were missing
    after a month of hard work the yugi was done so far. I added everything and sanded it like hell.
    a few users said to me add more folds in his cloth. At first I was against it, but I thought about it and as more as I thought the more I liked it. After I added them I sanded and sanded and sanded again. After that I sprayed a kinda car primer over it called filler here. It makes a smooth surface and makes it possible to spray normal primer over it without the small scratches in the material. The painting will follow soon, as I decided not to cut it into pieces:
    By the way next project will be Van Fanel with wings and sword in 1/8.
    Die Figur gefällt mir gut. Hab ich dir ja schon mal gesagt. Besonders die Falten an der Hose sind sehr real geworden. Dennoch ein bisschen konstruktive Kritik: die erste Kette schien mir von der Größe her passender zu sein.
    Warum hast du für den Grundkörper eigentlich Fimo verwendet? Kommt das vielleicht billiger?
    Fimo und Green Stuff zu vermischen hab ich noch nicht versucht aber das wird wohl nicht mehr lange dauern.
    Danke für den guide
      Hab mich vertan.
      Guckst du Tuffskull oder GeOrc...
        stimmt nicht Pitty...das fimo reagiert auf die chemie im gs. Anfänglich ist das GS zwar noch recht weich, aber nach ca 3 Tagen hat es das fimo soweit ausgehärtet, daß es wie Stein wird. Der Yugi ist jetzt um einiges härter, als es gs je geworden wäre. Wie könnte ein Tip vom Meister Goatman schlecht sein....
        Fimo als Kern hat den einfachen Vorteil, daß ich nach ner halben Stunde drauf modellieren kann und es einfach ne härtere Grundstruktur gibt als gs. Pattex Powerknete würde es aber warscheinlich auch tun.
          Ich arbeite ebenso mit gestrecktem Green Stuff, allerdings verwende ich Super Sculpy. Diesen Tip hab ich von Thomas Thoss, ehemaliger GW´ler. Der Vorteil liegt darin das man das Green Stuff wesentlich länger bearbeiten kann. Außerdem lässt es sich besser glätten. Ein weiterer positiver Effekt ist das es sich jederzeit wieder mischen lässt, somit entstehen keine Falten und Verwerfungen, die mir früher regelmäßig Probleme bereitet haben. Eine eigenart von Green Stuff das sich angehärtetes Material nicht mehr mischen lässt...
          Soweit Gruß Ge
          CoolMiniOrNot Ranking
            wobei der negative effekt wie du ihn beschreibst noch mehr bei älterem green stuff, wie das von gw auftaucht. kauft man es wo anders, wo es nicht verblistert ist und neuer....ist es noch ne ecke weicher von natur aus.
              Wo bekommt man dieses Super Sculpty her? ist sicher ganz nützlich!
              .o_o this isn't Bunny.
              (O_o) this is a hamster.
              (> <) and he hates you all.
              Become my slave!
